Golf mk4
Wazzzer
what is the likely outcome ?
Topic: what is the likely outcome ? (Read 2035 times)
welshdean
GTI forum regular
14 June 2013, 00:21 »
I've just had a quick read about different kinds of diverter valves / dump valves.
I've currently got a forge 007p but not entirely pleased with the noise. I fully appreciate that it's never going to sound like a Scooby but the Bailey's dv26 sounds excellent and also the forge splitter sounds quite nice.
My engine is an agu and I'm wondering if I put one of these on instead of the 007p, what will be the worst case scenario. As I'm still trying to get the noise
Nino
Re: what is the likely outcome ?
14 June 2013, 00:22 »
Take a read on this mate
http://www.golfgtiforum.co.uk/index.php?topic=94010.0
Like my badge? Get one here:
https://www.golfgtiforum.co.uk/index.php?topic=291134.0
VW Car history
- Mk3 1.8 GL - Silver - 5 door, Mk4 1.8t - Silver - 3 door, Mk4 R32 - Black - 5 door, Mk5 GTi - Black - 5 door, Mk4 R32 - Deep Pearl Blue - 3 door, MK6 2.0 TDI - Graphite Blue - 5 door, MK7 GTD - Solid Black - 5 door.
Current
- MK6 GTi Edition 35 - Candy White - 3 door
welshdean
GTI forum regular
14 June 2013, 00:37 »
Yeah I've already had a read mate, but as I've got nothing to record the differences in the valves, all I have to go by is the lights on the dashboard. If this makes any sense
Nino
14 June 2013, 01:00 »
From all the research I have done, the AGU engine seems to be the only engine that you "can" use a blow off valve but people still advise against it.
VW Car history
Current
jamie16v
Guest
14 June 2013, 01:57 »
Come listen to my forge 007p and tell me it's not loud
Not that I want it loud, it just is. Like I told you, you need a remap in your life. More boost, more psssst.
Also the open filter I'm currently running makes it loud.
davemk4
14 June 2013, 06:46 »
The noise from stock to remap is double. My 007p very loud.... air filter s2000,tip,forge 007p, remap it sounds lush
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
welshdean
GTI forum regular
Reply #6 on:
14 June 2013, 11:49 »
What is needed in total to put an s2k filter on it. ?
My car is totally bog standard apart from 007p dv, I'm not familiar with the s2k but I'll look into it if it's suitable for mine
dom
10k hero
Back in a Mk4
Reply #7 on:
14 June 2013, 12:46 »
Have a look here:
http://www.golfgtiforum.co.uk/index.php?topic=255079.0
To fit an S2000 filter you'll need a silicone reducer, the filter itself and a heatshield.
welshdean
GTI forum regular
Reply #8 on:
14 June 2013, 13:04 »
Thanks for that dom, I've already got a filter here that's got a plastic surround to it and a hollow end so air can get through the filter. Is this a filter with already a heatshield around it ? Like I've said before I was given it to me by a guy who had it on his vectra 24v. Or do I still need a heatshield even with this. As I've looked on the net and only seem to find the exposed filters with heat shields.
I've yet to see a cone filter with a plastic casing and also a heatshield.
If that makes any sense
GTi_James
Reply #9 on:
14 June 2013, 13:36 »
Nino has one for sale?
Golf mk4
Wazzzer
