Author Topic: Help with re-plugging engine  (Read 946 times)
Offline Scott-R
  • GoT BoosT!
« on: 13 June 2013, 20:57 »
Can't find where to plug the connector on the left hand of the fuel rail..
Also having issues re-locating my power steering pipe does it go over gearbox or around the side?
Fault code p40413 - where would I find the plug that may be unplugged...
There may be a lot More questions tonight ha and tomoro...
Golf GTI ... What else would you have?
Offline Jin_C
Re: Help with re-plugging engine
« Reply #1 on: 13 June 2013, 22:44 »
What engine do you have?
On an AGU there will be 2 plugs to the left of the fuel rail. One will go into the underside of the throttle body that is bolted to the inlet manifold and the other will go into the cam sensor that is bolted on to the left of the rocker cover
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
jamie16v
« Reply #2 on: 14 June 2013, 01:58 »
And the inlet temp sensor
Offline Scott-R
  • GoT BoosT!
« Reply #3 on: 14 June 2013, 06:12 »
Auq engine.
Still coming up with that code and its p0413.
Thanks guys will have a look today.
Also getting slight screech frm gearbox I recon its the "thrust" bearing ha but colluded this be due to not being ran for a while as its pretty new.
Slight crack around filler level cap on gearbox casing causing seeping ATM this would be have been easy if I had noticed when I had it all off.......  :sick:
Thinking of aluminium brazzing it? Till the time I can be motivated to take it all apart again ha
