Golf mk2
timeing and idle revs what should they be??
Topic: timeing and idle revs what should they be?? (Read 1314 times)
t-dub1902
13 June 2013, 20:48 »
Hi
As you know i have mk2 16v
Getting the timing done and getting the idle revs set
What should it be idleing at??
And is there any spec i should be aware of on timing??
Gambit
Forum addict
Re: timeing and idle revs what should they be??
13 June 2013, 21:43 »
If still on kjet. Idle when warm around 950rpm
Timing marks on flywheel and also cam & crank pulley
Set co% to 2.0% and make sure you set it all with red wire at coil disconnected
t-dub1902
14 June 2013, 15:50 »
Cheers dude really appreicated!!
Golf mk2
