Author Topic: Magnetic sump plugs  (Read 1985 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
Magnetic sump plugs
« on: 12 June 2013, 18:47 »
Anyone use them on any of their vehicles?
They do what they say on the tin I guess, wondering if anyone has actually pulled out any small chunks of metal or the like when using them... :rolleyes:
One is for sale for cheap, like almost the same price as a normal sump plug and I am changing the oil soon, wondering if it is worth it.  :rolleyes:
Offline spikenipple
Re: Magnetic sump plugs
« Reply #1 on: 12 June 2013, 19:57 »
They attract tiny particles of metal floating around in the oil which are smaller than the filter element size of the oil filter. Can only be a good thing to take those away from the oil.
Offline tweed
« Reply #2 on: 12 June 2013, 20:02 »
Personally cant see the point! Theres not a lot of bolt to collect any metal.
You shouldnt be and chunks of metal in there. If there is then you have a problem.
I normal check my drained oil with a high powered magnet on a long bolt.
If your oil looks like someone has poored a tube of glitter in there, then again you have problems.
I wouldnt bother, but at the price then why not?
Offline Adzg60
« Reply #3 on: 12 June 2013, 22:40 »
ive had one on my previous mk2 and although I never had any issues regarding wear or reliability there was very small bits of swarf present.
not sure where it would have come from.....
Offline Sam
  • Sam I am
« Reply #4 on: 13 June 2013, 09:52 »
The amount of times I have detonated the engine on my MK2 im sure that they have stopped it from clogging up other bits. Go for it, its only a sump plug
Offline danny_p
« Reply #5 on: 13 June 2013, 22:41 »
magnetic gearbox plugs are good
sump plug, as long as it dosent leack it can't do any harm can it
all the VW's have gone bar 1.
