Author Topic: help needed please (new problem added )  (Read 2229 times)
Offline cullygti
« on: 12 June 2013, 11:05 »
First off hello chaps been out of action for quite a while but am now nearly back  :grin:
Got a problem with the golf again after a long drive turn off engine and the car won't start until it's cooled down start driving and it just cuts out and takes a while before it will start again any ideas where I should be looking or what I am looking for to solve this would be great cheers guys engine is agu and mapped for over 2 years and only starting to do this since yesterday cheers guys
« Last Edit: 12 June 2013, 16:08 by cullygti »
Offline Nino
Re: help needed please
« Reply #1 on: 12 June 2013, 11:28 »
ant that something to do with the crank sensor?
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline GunnerCP
« Reply #2 on: 12 June 2013, 11:31 »
I believe so.....
Offline dom
  • Back in a Mk4
« Reply #3 on: 12 June 2013, 11:41 »
That would be my guess as well.
jamie16v
« Reply #4 on: 12 June 2013, 12:46 »
couldnt it be the coolant temp sensor too?
welcome back cully btw  :laugh:
Online barrym381
« Reply #5 on: 12 June 2013, 15:27 »
a diesel audi of a mates was doing this turned out to be a fuel pump relay  :smiley:
Offline cullygti
« Reply #6 on: 12 June 2013, 16:05 »
Cheers guys I had a feeling it was summat to do with crank sensor but wanted to be sure cheers again guys as always very much appreciated
Offline cullygti
Re: help needed please (new problem added )
« Reply #7 on: 12 June 2013, 16:10 »
Hi chaps yet another problem  :sad:
Power steering fluid as been topped up from empty 4 times since Friday there's no obvious signs of leaks it seems it's losing fluid when in motion or under use is it the pump that is failing or is it a seal or summat all help appreciated cheers guys
Offline GunnerCP
« Reply #8 on: 12 June 2013, 16:31 »
I've had these issues before and it was the pump that was knackered, I bought a reconditioned/rebuilt one for around £80 iirc, no idea if you can DIY it though, wasn't something I was interested in doing!
Offline Bellend
« Reply #9 on: 12 June 2013, 16:44 »
Fluid has got to be going somewhere matey, not like it can go into the engine. Put cardboard under it and turn it stationary lock to lock with engine running, put a bit of stress on it. Should see it dripping, or jack it up and take a look, should be obvious.
Where all my moneys went.
