Author Topic: squeel issue  (Read 1134 times)
Offline GTi_James
squeel issue
« on: 11 June 2013, 16:40 »
afternoon guys,
started noticing a squeel from the front somewhere when i apply brakes but this only happens when i apply slight to slightly moderate pressure theres a squeel but dissapears ones full breaks are applied to come to a stop   :huh: strange huh!
anyone with any ideas?
Offline navmk4gti
Re: squeel issue
« Reply #1 on: 11 June 2013, 16:48 »
Brake dust  :undecided:
You could jack it up and give the wheel a spin just for piece of mind if your thinking wheel bearing :grin:
Offline GTi_James
Re: squeel issue
« Reply #2 on: 11 June 2013, 17:04 »
been there since Jan perhaps. thought it was a stone or something and it'll sort itself out but not the case. felt the side of the disc thats facing outwards but no imperfections gonna give a feel about the other side and see if theres and issue with that, also getting a rattle when pulling off and turning  :sad:
god damn car
« Last Edit: 11 June 2013, 17:27 by GTi_James »
Offline navmk4gti
Re: squeel issue
« Reply #3 on: 11 June 2013, 23:08 »
Mine did that on the agu and was fooked wheel bearing use to squeel over humps too
Offline Nino
Re: squeel issue
« Reply #4 on: 11 June 2013, 23:27 »
Be leave it or not the most common cause of this type of thing is wait for it....... Vibrations on the back of the brake pad, where there hasn't been enough copper grease applied. Or your brake pads are really low.
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline GTi_James
Re: squeel issue
« Reply #5 on: 12 June 2013, 07:56 »
well i though it was a copper grease issue so applied more but no luck still there though i've managed to narrow it down now to a squeal between 1quarter to 3quarters brake pressure whilst turning left and sometimes right so must be brake pads, thing is they were new as of last october, worthwhile changing me thinks?
