Golf mk4
Wazzzer
suspension
Topic: suspension (Read 926 times)
crazydog
suspension
11 June 2013, 14:02 »
hi guys someone tell me best way to press in front wishbone bush no prob getting old one out,haven't tried to put new ones in yet poly bushes is it easier tilting to get the lip started . cheers.
scarr89
Mk4 Golf, DERV FTW!
Re: suspension
11 June 2013, 14:43 »
I think people normally use a press. Or make your own little puller type thinggggg. If you get the correct puly bush ones I think they come in two pieces, making it super easy to get it in.
jamie16v
Guest
Re: suspension
11 June 2013, 15:15 »
a decent vice will do the job just fine. you`ll need to keep turining the arm to get the bush in even and do it bit at a time though. the end result is the same if you cant get to a proper press.
dom
10k hero
Back in a Mk4
Re: suspension
11 June 2013, 17:49 »
Did mine in a vice
SI74
Re: suspension
11 June 2013, 17:56 »
I did my rears using this lot if you dont have a vice.
Was real easy to do, should work the same on the fronts
Golf mk4
Wazzzer
suspension
