Author Topic: Forge Splitter DV quiet?  (Read 2652 times)
Offline Wally989
« on: 11 June 2013, 10:16 »
I bought a forge splitter valve the same as this:
http://www.forgemotorsport.com/content.asp?inc=product&cat=0006&product=FMDVSPLTR
and installed it on my mk4 golf 1.8T last night but it doesnt seem to make much of a wooosh?  :angry:
Everything is standard on the car apart from the DV. What can i do to get more of a woosh noise?
Offline Granta Gti
Re: Forge Splitter DV quiet?
« Reply #1 on: 11 June 2013, 10:48 »
You can adjust them by twisting the top so try that.
Offline welshdean
« Reply #2 on: 11 June 2013, 11:03 »
I was always under the impression that the splitter was no good because they keep throwing up fault codes , I was looking to get one for my agu but was advised against it.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 11 June 2013, 11:13 »
AGU wouldn't care, it's more down to the air recirculation
Offline Wally989
« Reply #4 on: 11 June 2013, 11:19 »
mine is AGU and ive drove around 40 mile with it on and no fault codes on the dash at the minute. Ill adjust the top when i finish work.
Has anyone used the splitter dv before on a standard mk4 and know how many clicks it should be on?
Offline navmk4gti
« Reply #5 on: 11 June 2013, 12:42 »
I had it on my old agu for a while.. and after remap i felt the slight dip in power it was causing at about 4k revs. 007p or 008 is the way to go you will feel the boost hold well through the rev range :wink:
Offline jman-gti aum
« Reply #6 on: 11 June 2013, 16:46 »
Had one on a standard aum for 6 months with no problems, might put it back on and see how it is with stage one but the are a pain to set up. But is not going to sound any thing like a Subaru. :laugh:
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #7 on: 12 June 2013, 09:16 »
Might sound a little obvious but have you installed it the right way round? It has to be installed the other way round to the standard bosch valve and the 007.
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline Wally989
« Reply #8 on: 13 June 2013, 10:00 »
I know it wont sound like a subaru but a little ptshhhhh would be nice  :laugh:
Offline Wally989
