Author Topic: Make these brakes fit?  (Read 3404 times)
Offline molegti
Re: Make these brakes fit?
« Reply #10 on: 12 June 2013, 18:07 »
Try removing the slider pins and greasing them
Offline Sam
  • Sam I am
« Reply #11 on: 12 June 2013, 19:37 »
I feel that fitting these callipers is slightly over ambitious for your technical skills if you are asking how to unseize/unstick your current set-up. I run G60s on my MK2 16vt and the only issue is the tyres loose grip rather than a lack of breaking power.
Offline Diamond Hell
  • Opinions я Us
« Reply #12 on: 12 June 2013, 19:51 »
Maybe if you had more control over your loose tyres you wouldn't have issues with how much your car breaks?
Offline Sam
  • Sam I am
« Reply #13 on: 12 June 2013, 20:23 »
So coming into the pre-bend bumpys on a damp road has never caused you to lock up a little?
  • Opinions я Us
« Reply #14 on: 12 June 2013, 23:49 »
It's because of the breaking power of your car that this never happens to you.
Because your car never moves.
Offline Gambit
« Reply #15 on: 13 June 2013, 17:02 »
Apec are crap also
Offline Craigwilson
« Reply #16 on: 13 June 2013, 17:05 »
It takes a bit more than fitting callipers to test my technical ability
« Reply #17 on: 13 June 2013, 23:47 »
They are overkill on a mk2, light car and as said 280mm set up will be fine.
