Author Topic: Fuel grade  (Read 5775 times)
Offline Torch
Fuel grade
« on: 10 June 2013, 21:09 »
A question to ponder!
I have always put 99 octane grade fuel in my Mk V GTI as I heard years ago that this fuel type was not only a higher grade but less prone to contamination.
Have you guys thought what you intend to put in your GTI?
Offline CraigW
Re: Fuel grade
« Reply #1 on: 10 June 2013, 21:43 »
I've went out my way in my current car to only use vpower. I'll be using the same in the new car
Offline Bill_the_Bear
  • Yes! Wait a minute... No!
Re: Fuel grade
« Reply #2 on: 10 June 2013, 21:45 »
Anyone know of a comparison between the major premium brands.  Tesco 99 seems pretty good value.
Offline Flintymutt
Re: Fuel grade
« Reply #3 on: 10 June 2013, 21:56 »
VPower and nothing but
Offline Hobojim
Re: Fuel grade
« Reply #4 on: 10 June 2013, 21:57 »
I read a good article about a comparison between the 'premium' fuels. Tescos came out top. I will try and find it for you. They ran the same car on each one for x weeks, noted economy and dyno'd them.
Offline Jimble
  • Moderator
Re: Fuel grade
« Reply #5 on: 10 June 2013, 22:09 »
As good as any review i've seen:
http://m.youtube.com/watch?v=WTaBngvsPrc
Offline Hobojim
Re: Fuel grade
« Reply #6 on: 10 June 2013, 22:15 »
Offline AlanH
Re: Fuel grade
« Reply #7 on: 11 June 2013, 19:57 »
http://www.pistonheads.com/gassing/topic.asp?t=302977
Have a read.
That was way back in 2006, and there are quite a few conflicting views in the discussion that follows the article.
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Re: Fuel grade
« Reply #8 on: 11 June 2013, 22:09 »
Ah, but are these conflicting views supportable ones.  In other words do they stand up to the same standard of scientific test as the article, or are they more anecdotal? :tongue:
Offline Hobojim
Re: Fuel grade
« Reply #9 on: 12 June 2013, 01:05 »
Have a read.
With bill on this one Alan. I'm always going to give more weight to the well explained article than the fella that dyno'd his cosworth worth once.
I'm in the business and I assure you petrol has changed very little since it became unleaded. A few additives here and there but the chemistry is identical.
