Author Topic: duff turbo?  (Read 3686 times)
Offline Screech16v
  • MK3 20vt AGU
duff turbo?
« on: 10 June 2013, 20:42 »
Right guys ive just purchased a second hand ko3s and need some advise,it came today and tbh I think its past its best  im no turbo expert btw  ,it was advertised as 80 odd k, in good working order,no play in the shaft ,no smoke bla bla,well opened the box and after a quick look over it these are the things are what im not happy about, shaft has enough play for the turbine to touch the housing,is this normal without oil pressure? Its got a bit of oil around between the hot and cold sides
Has two cracks in the hot side which I could probably live with as I believe many out are the same but was not mentioned,some oil in the cold side pipe (engine breathing?)
Its been badly packaged and the actuator bracket is bent plus the vacuum spout is sqaushed ,its the play in the shaft that im worried about ,i wouldn't sell  it like this
Was hoping to get this straight on but I don't think it would last long,ive pmd the seller to see what he says
What would you do ,rebuild it? send it back?
Offline dom
  • Back in a Mk4
Re: duff turbo?
« Reply #1 on: 10 June 2013, 20:44 »
Send it back, there are enough KO3s' around to pick up a decent one :wink:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: duff turbo?
« Reply #2 on: 11 June 2013, 11:54 »
The oil sounds like it is in need if refurbishment too. Will be passing oil through its seals
Buy my old K04 instead, much better than a poxy ko3s :grin:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Screech16v
  • MK3 20vt AGU
Re: duff turbo?
« Reply #3 on: 11 June 2013, 18:23 »
He's saying there was no play and has video evidence  :rolleyes: ,wont take it back,the courier has worn the bearing out then,thats that mystery solved
Offline Screech16v
  • MK3 20vt AGU
Re: duff turbo?
« Reply #4 on: 11 June 2013, 18:26 »
I would love to buy your cast offs brad but im skint now but I do have a broken turbo to look at .
Offline F17BAD
Re: duff turbo?
« Reply #5 on: 11 June 2013, 18:40 »
haha cast off   :grin:
served me well that K04, much better than K03S, but i hear you
not good, hope u get it sorted
Offline Screech16v
  • MK3 20vt AGU
Re: duff turbo?
« Reply #6 on: 11 June 2013, 19:00 »
Cheers mate,im losing all faith in our classified section tbh as im not having much luck lately  :undecided:
Offline F17BAD
Re: duff turbo?
« Reply #7 on: 11 June 2013, 22:40 »
Cnunts trick mate if the seller is been a tw4t
Offline FlashRedThree
  • MK III Flash Red 1.4 SE + MK V DBP 2.0T GTI
Re: duff turbo?
« Reply #8 on: 11 June 2013, 22:43 »
PayPal claim and send it back anyway?
Offline Screech16v
  • MK3 20vt AGU
Re: duff turbo?
« Reply #9 on: 11 June 2013, 22:55 »
Paypal will be dealing with it now,going to go get it inspected for an official report ,I aint havin it,ive payed good money for a piece of crap that I cant use and the report will prove it ,its just annoying that the seller still says there was nothing wrong with it when he had it, ffs I only got it yesterday! Plus the packaging was an absolute joke!a massive box with a couple bits of paper floating about so really its got damaged because the seller cba to do it proper,just cant get the staff these days  :angry:
