Author Topic: clutch adjuster  (Read 2347 times)
Offline pal1
clutch adjuster
« on: 14 October 2003, 10:25 »
just brought a 16v but the clutch pedal is high if you push the pedal right down it doesnt change properly but half way down it does.
 the problem is its a self adjusting cable and it cant be adjusting right its had a new clutch so it cant be that is there any thing i can do or is it just one of those things you cant change  ???
Offline Gambit
Re:clutch adjuster
« Reply #1 on: 14 October 2003, 10:27 »
swap it for a manual adjustment cable
also, see the other post about the clutch pedal being too high
Offline pal1
Re:clutch adjuster
« Reply #2 on: 14 October 2003, 12:54 »
is it a straight swap ? :)
Offline dubslug
Re:clutch adjuster
« Reply #3 on: 14 October 2003, 18:46 »
yeah it should be. take ur old one out new one in in less than ten mins, ive just done mine it was so easy
1992 pearl grey 8v
Offline modulater
Re:clutch adjuster
« Reply #4 on: 15 October 2003, 02:13 »
When I fitted a new clutch on my car I also fitted a new cable and it cured the problem you describe. I fitted an automatic adjusting one and it was fine but took ages for it to bed in, it was between clicks for a while.
