Author Topic: Engine coolant!  (Read 802 times)
Offline tomjoruk2013
  • 2.0 GTi
Engine coolant!
« on: 10 June 2013, 17:59 »
After a long is journey or after a couple of weeks my engine coolant will run low, I can't see a leak, the engines running fine and performing how it should? Does anyone have any tips of where typically to look for a leak?  God I hope it's not the head gasket! HELP
Offline ant_gti
  • mk3 20v turbo
Re: Engine coolant!
« Reply #1 on: 10 June 2013, 18:40 »
plastic flanges,coolant pipes,radiator. Have you noticed any puddles under the car?
  • 2.0 GTi
Re: Engine coolant!
« Reply #2 on: 10 June 2013, 18:43 »
Nope no puddles, I checked earlier, can't think what it would be, all the pipes are bone dry
Offline james2
  • No scammers please.
Re: Engine coolant!
« Reply #3 on: 10 June 2013, 20:59 »
mine got a pin hole leak on a pipe that sits behind the fan. The fan cut into it.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
