Author Topic: Poor starting  (Read 4124 times)
Offline Mr Blue
Re: Poor starting
« Reply #10 on: 09 August 2005, 23:09 »
sounds like you have a digifant 8v engine.
Sometimes the ECU can play up causing the fuel pump to stay constantly on. it should 'prime' for about 3 second when you turn the ignition.
go have a listen mate
you will need to change the ecu if thats the case :smiley:
Offline D4NNY
Re: Poor starting
« Reply #11 on: 09 August 2005, 23:11 »
nah, pump primes for like a second, then stops, until you crank the engine over
__________________ <br />|^^^^^^^^^^^^ | || __ <br />|___GOLFGTI.CO.UK_| ||'|";\\,_ <br />|(@)'(@)""*''|(@)(@)***(@)__|
Re: Poor starting
« Reply #12 on: 10 August 2005, 09:51 »
Replace the blue temperature sender before you do anything drastic, not expensive and defo the first thing to look at with digifant problems :)
Offline naut2k5
Re: Poor starting
« Reply #13 on: 10 August 2005, 15:16 »
What is this blue temp sensor exactly ?
Re: Poor starting
« Reply #14 on: 10 August 2005, 16:47 »
Its the temperature sensor for the ECU, so the ECU can control cold running & starting :)
Offline ...joe
Re: Poor starting
« Reply #15 on: 10 August 2005, 17:38 »
..... for some reason it is amazingly important in getting digifants running right.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline D4NNY
Re: Poor starting
« Reply #16 on: 10 August 2005, 18:37 »
is this the one located just on the side of the block, above what i can anly assume is the thermostat?
Offline ...joe
Re: Poor starting
« Reply #17 on: 10 August 2005, 18:41 »
no its in front of the head on a plastic housing, between spark plugs 3 & 4. it's the closer one to the head if yours is too dirty to tell if its blue or not!
Offline D4NNY
Re: Poor starting
« Reply #18 on: 10 August 2005, 19:13 »
are all golf bits transferable, my brother has a j reg 1.6, was wondering if i could swap bits over? i think it could be fuel pressure related, as the pump primes every time you turn on the ignition, is this right or wrong?  i thought they only primed to a certain pressure then stopped?
Re: Poor starting
« Reply #19 on: 10 August 2005, 22:43 »
not much on a 1.6 that'll be any use engine wise, the pump should always prime for a short time no matter what :)
Follow the top hose from the radiator and it leads to the flange I'm talking about, you should have 2 sensors in there black & blue.  Black is for the dash cluster & blue is for the ECU :)
