Author Topic: Winter wheels  (Read 17079 times)
Offline Hobojim
Winter wheels
« on: 09 June 2013, 22:32 »
In all seriousness it is looking like I should be planning for winter boots. What are people's thoughts on winter tyres. I have never had a car with 18"s on it, should I be looking for a set of smaller alloys to put the chunkier rubber on? If so any recommendations? I'd like to keep something with vw centre caps on even if they are non oem.
Edit: 225/45 18R tyres are expensive! Cheapest I found on a quick search was £185 each!
Edit 2: black circles have them at 150 each.
« Last Edit: 10 June 2013, 00:16 by Hobojim »
Offline Bill_the_Bear
  • Yes! Wait a minute... No!
Re: Winter wheels
« Reply #1 on: 09 June 2013, 22:36 »
What a rip off!
Offline mcmaddy
Re: Winter wheels
« Reply #2 on: 09 June 2013, 22:51 »
no real point putting 18” winters on. kind of defeats the object really. 17” would be better and cheaper.
Offline firefly125
Re: Winter wheels
« Reply #3 on: 09 June 2013, 23:25 »
Hi  agreed 17  inch alloys would seem sense , but wot if you have the pp option would 17 's still fit ?
Re: Winter wheels
« Reply #4 on: 09 June 2013, 23:45 »
No.  Not on the fronts at least... not sure about the rear.
Offline Hobojim
Re: Winter wheels
« Reply #5 on: 10 June 2013, 00:11 »
I've done some googling and it appears you can get up to 335mm brakes under 17" alloys if you choose carefully. 344mm apparently fit under most alloys. So PP 340 mm discs should be ok as long as the callipers are not stupidly big.
Anyone know anything about the PP callipers over the standard ones?
Offline mcmaddy
Re: Winter wheels
« Reply #6 on: 10 June 2013, 07:49 »
Would be interesting to see what VW offer you if you ask for a winter wheel package and you have the PP on your GTi. A british pound says they will say the 16" winter whell package will be fine hahaha
Offline DougL
Re: Winter wheels
« Reply #7 on: 10 June 2013, 08:06 »
So what size wheels will go over a non power pack car's brakes?
Tornado Red GTI 3dr manual
Previous Golfs Mk1 GLS and GL, Mk2 GL and Driver, Mk3 GL, Mk4 GT TDI, Mk6 TDI (and a Mk2 Scirocco 20 years ago)
Offline Ess_Three
Re: Winter wheels
« Reply #8 on: 10 June 2013, 08:20 »
16"
..but gaining motorcycles.
Offline Ess_Three
Re: Winter wheels
« Reply #9 on: 10 June 2013, 08:22 »
How so?
I run 18" winter tyres on both my Mk6 GTI and Mk5 GT TD...and manage just fine, in conditions where the standard tyres (Goodyear Eagle F1s) wouldn't get the cars off the driveway.
17" may give you more protection...but the point of winter tyres is the compound and tread design...not the size.
