Author Topic: revs drop no pattern and no not maf  (Read 965 times)
Offline davemk4
« on: 08 June 2013, 08:53 »
2001 aum. With no pattern or temp relation my rev drop quite low car judders slighlty. Now maf is new genuine VW not refurb. Boost pipes all good. The usual crap breathers near front all ok or new. I use a k&n so wondered if maf caked in oil? Only 4 months old.?? No error lights no codes pending no drive problems. To clean maf what best quick spray of carb cleaner? Any other suggestions
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
jamie16v
Re: revs drop no pattern and no not maf
« Reply #1 on: 08 June 2013, 09:42 »
So, in your title you say it`s not the maf, then you ask if it`s caked in oil?...
try unplugging it and see if it makes a difference. as you know k&n are know to use oil as a part of its air cleaning process.. i would use electrical cleaner rather than carb cleaner, but i cant see carb cleaner harming it to be honest.
Offline dom
  • Back in a Mk4
« Reply #2 on: 08 June 2013, 09:44 »
Dirty throttle body?
jamie16v
« Reply #3 on: 08 June 2013, 09:52 »
most likely :wink:
Offline davemk4
« Reply #4 on: 08 June 2013, 10:20 »
Throttle body was gutted when car was gutted in january. All was cleaned and along with pipe breathers etc. Thing is the fault has no pattern when it does it. Today not once yesterday 4 times
Offline 52GTIPETE
« Reply #5 on: 08 June 2013, 12:30 »
PCV valve. Will be a hair line split somewhere
Offline davemk4
« Reply #6 on: 08 June 2013, 15:00 »
Ill check it later
