Author Topic: Boot light door light rear wash jet  (Read 947 times)
Offline GtiTurbo 79
« on: 07 June 2013, 11:39 »
Hi all my boot light has stopped working plus my
Passenger door light has as well swapped bulbs over still
No joy any help would be great full plus rear wash jet has doesn't work
Pump going fine I've took trim off boot to see if the pipe
Had come off but it hasent  :laugh:
Offline pickles
  • Next!!!
Re: Boot light door light rear wash jet
« Reply #1 on: 07 June 2013, 12:20 »
microswitches can be a problem.
iv just got my boot light working accidentally while changing my tailgate, i think the microswitch connector wasnt making good contact on my old tailgate.
your rear washer. take the pipe off and have someone operate the rear washer n see if theres any water coming through, if not its blocked.
theres a connection from the pump on the washer bottle in the engine bay that goes into the inner wing and to the rear, i noticed mine had split just as it went into the wing :(, helped that i noticed a big puddle under the car tho  :grin:.
might be worth giving your washer connections a good looking at.
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline budgie
« Reply #2 on: 07 June 2013, 12:34 »
my rear jet wash doesnt work either and just checked, hear the pump running but see a puddle of water at drivers side wheel :sad:. il check all pipes later, no time today.
Offline Mark b
« Reply #3 on: 07 June 2013, 14:41 »
I had the same prob with my rear jet just behind the roof lining on the left is the connecter for the hose sounds like its just unclipped very simple job takes a matter of minutes it's just behing the boot gromit
Standard gti 2.0 115bhp 2000 w reg
