Author Topic: relay location ?  (Read 1205 times)
Offline matty james
relay location ?
« on: 06 June 2013, 14:57 »
in relation to my other post , can any body tell me where the relay for the fuel pump is, as i hope it is this rather than the pump its self if that is my problem . thankyou  :smiley:
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline budgie
Re: relay location ?
« Reply #1 on: 06 June 2013, 15:07 »
code 0411?. its under the steering wheel i think. ive just been there :smiley:
Offline budgie
« Reply #2 on: 06 June 2013, 15:13 »
just seen ur last post.. not sure about ur starting problems but still do think fuel pump relay is under the steering wheel.
Offline matty james
« Reply #3 on: 06 June 2013, 15:17 »
just looked in maintance section and it says its under the side kick panel on drivers door. still not sure where this relates to, any ideas?  :smiley:
jamie16v
« Reply #4 on: 06 June 2013, 15:29 »
« Last Edit: 06 June 2013, 15:33 by jamie16v »
Offline matty james
« Reply #5 on: 06 June 2013, 15:38 »
i been in my fuse box , but i thought relays where large than fuses that are in that box on side of dash, or am i just being dumb ??  :embarrassed:
jamie16v
« Reply #6 on: 06 June 2013, 15:39 »
you`re just being dumb  :wink: look underneath the dash, above the accelerator pedal, there might be a panel needs removing, not sure, my interior has been stripped a while now, but they are under there!
(they are not in the same panel as your fuses)
« Last Edit: 06 June 2013, 15:42 by jamie16v »
Offline matty james
« Reply #7 on: 06 June 2013, 15:44 »
yeah your right bud , im being dumb , didnt scroll down ur post far enough,  :embarrassed: thanks 4 your help bud :wink: hope this is where my problem lies, thanks again.
Offline matty james
« Reply #8 on: 06 June 2013, 19:55 »
thanks for advice guys :smiley:
