Author Topic: help does anybody know my problem ?  (Read 1169 times)
Offline matty james
« on: 06 June 2013, 13:55 »
hi all, just wash my car and was going to go for a run out as it is sunny, but she wont start :sad: noticed a faint humming noise coming from the back end yesterday morn while going to work and monday morning she took an extra couple of seconds to fire up on the key . now when i turn the key every thing happens but firing up . i have no lights staying on and all electrics seem to work. so wondering if its a fueling problem? cant smell any petrol under bonnet even after putting foot on gas pedal while turning the key to try and start her. it an auq engine, anybody any thoughts? i av got acsess to a code reader but 18mile away. so  just wondering what it could be, any thoughts anybody ,thanks in advance.
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline GTi_James
Re: help does anybody know my problem ?
« Reply #1 on: 06 June 2013, 14:01 »
battery? i know mine would turn and all the lights came on but no engine start  :undecided:
Offline matty james
« Reply #2 on: 06 June 2013, 14:52 »
thanks, will check that now, but i think it going to be more costly than that ,but ur right  u shud alway check simple thing 1st  :smiley:
Offline pickles
  • Next!!!
« Reply #3 on: 06 June 2013, 17:34 »
start with the simple stuff.  Air, Fuel, Spark, make sure youv got all 3.
Does your immobiliser light go off when the keys in ?
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline navmk4gti
« Reply #4 on: 06 June 2013, 19:29 »
Mine did this and was fooked battery. Gt some jump leads on it if its starts you know its the battery.
Offline matty james
« Reply #5 on: 06 June 2013, 19:49 »
theres no imobilser light on, battery ok, its a fueling problem, just pulled out fuel pump relay and plugged it back in and the fooking thing starts again, but still got humming noise coming from the fuel pump, so ithink its either pump or pump relay thats at fault ,fingers crossed its relay .will get anew one tomorraw an find out :smiley:
