Author Topic: Will sticking wire along in with a fuse increase load on fuse?  (Read 5429 times)
Offline madsb
Well basically the question the title says.. If I put wire on one end of the fuse and put the fuse back in the box, will drawing power from that wire increase the load on the fuse? I think no, but I'm really not sure..
Offline Screech16v
  • MK3 20vt AGU
FIRE !  :grin:
Gavv8
I'd like to hear you explain that to the nice man from the fire brigade.... :grin:
Offline CJA321
Why lol? Sorry but uprating fuses is never a good idea, let alone adding bits of wire in!
Offline madsb
Haha no fire lol.. Same principle as a fuse tap, just the hack solution...
Gavv8
Just to satisfy my curiosity, what is the purpose of doing this?
Offline northeast_gti-t
  • "1.8T AGU"
To torch his golf  :grin:
2000 Mkiv GTi 1.8T AGU
VW BUSH
Think about it, if you pull more amps through a fuse than the fuse is rated for it blows.....
Offline itavaltalainen
if you stick a wire parallel to a fuse the current will split.... how much goes where depends on the resistance of each path. this cannot be accurately predicted even when only using 2 wires of the same diameter (length of wire will already make a difference, then how it's connected up)....
very daft to try this with fuse (even if fuse blows the wire will still be there and happily conduct many amps => buy some cookies for the fire department before attempting)
Offline GOLF-MK3-GTI
haha, good one  :grin:
