Author Topic: Very slight knocking  (Read 1201 times)
Offline Rod1-gti
« on: 03 June 2013, 22:30 »
Hi guys. i bought my golf on Saturday and have noticed that after driving for a bit, and then left to idle there is a very slight knocking sound (so slight, i think Im being paranoid)
My question is; should the 20vt be run on super unleaded with a higher ron? as i know this can resist pinking.
Offline pickles
  • Next!!!
Re: Very slight knocking
« Reply #1 on: 04 June 2013, 11:10 »
knocking from where m8
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline navmk4gti
« Reply #2 on: 04 June 2013, 16:28 »
I would give it a service as crappy old oil or low oil can make them a bit noisey... and as for fuel 95 ron is fine unles its mapped then use super unleaded :wink:
Offline Rod1-gti
« Reply #3 on: 04 June 2013, 17:32 »
Thanks guys.
It just sounds like someone is lightly knocking on the plastic engine cover. Its been well serviced, it has fvwsh.
I have been told there is some sort of solonoid on them that can rattle?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 04 June 2013, 17:33 »
ticking can be the charcoal canister or even the injectors
« Reply #5 on: 05 June 2013, 13:37 »
Drop the sump and check or replace the oil pump pick up pipe could be blocked.
Offline Rod1-gti
« Reply #6 on: 06 June 2013, 19:09 »
Filled her up with a higher octane fuel and it seems to have done the trick :)
