Author Topic: ERRATIC SPEEDO!!!!!!!! HELLLLLLP  (Read 3309 times)
Offline chen
« on: 03 June 2013, 22:00 »
hello all       new to the vee dub scene just got my self a mk1 1.8 gti cabriolet c reg and the speedo sticks at 20mph and then goes to 120mph when iam doing about 10mph any ideas why ??????? please got loads mre probs but one at a time thanks for any help
Offline raferackstraw
Re: ERRATIC SPEEDO!!!!!!!! HELLLLLLP
« Reply #1 on: 05 June 2013, 23:46 »
could be the worm drive on the end of the speedo cable in the gearbox or the spring on the needle,
follow cable to where it enters the gearbox and you will find a little plate held on by a bolt, undo bolt and carefully pull out cable[ do this very gently as you dont want worm drive to catch on casing and fall into box!!!!!!! ]
inspect the gear for missing teeth/damage etc and replace if necessary.
if thats ok then its likely to be the speedo itself, replace speedo as the needle spring or gears in speedo are fubar  :wink:
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
