Author Topic: Red injectors are these correct?  (Read 2550 times)
Offline Scott-R
  • GoT BoosT!
« on: 03 June 2013, 15:39 »
Are these the correct injectors and anyone else used this company?
http://www.neobrothers.co.uk/bosch-injector-saab-9000-ng900-b204-turbo-p-2903.html
Golf GTI ... What else would you have?
Offline Scott-R
  • GoT BoosT!
Re: Red injectors are these correct?
« Reply #1 on: 03 June 2013, 15:42 »
And is this the correct housing?
http://www.ebay.co.uk/itm/VW-GOLF-MK3-VR6-AIR-MASS-FLOW-SENSOR-MAF-021-906-462-A/330602446768?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D8117594093510172768%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D121112904887%26
Would it be worth me getting the injectors and housing??
I'm currently pushing 254bhp on stage 2 revo, with standard fuel pump standard injectors and standard housing.
Ko4-001 and most other mods just not fuelling.
jamie16v
« Reply #2 on: 03 June 2013, 17:27 »
they look the boys!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 04 June 2013, 14:43 »
AGU?
Offline Scott-R
  • GoT BoosT!
« Reply #4 on: 09 June 2013, 13:33 »
Auq.
Offline Scott D
« Reply #5 on: 09 June 2013, 15:35 »
BAM TT/LCR/S3 injectors 380cc are direct fit for AUQ
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 09 June 2013, 16:25 »
Yup Saab reds are only for us AGU boys
Offline Scott-R
  • GoT BoosT!
Offline Scott-R
  • GoT BoosT!
