Author Topic: Question about green spring vs yellow  (Read 1301 times)
Offline Nino
« on: 03 June 2013, 12:56 »
Some of you will remember after i bypassed my n249 that i was worried because the "tsssssh" on my 007p changed to a slight but only very slight flutter. However i lost no power at all and my boost got to about 6-7psi then would fall and hold at 5.
Some suggested i try a yellow spring and thanks to dean giving me his i took the car out for a run and she still has that tiny flutter but now shes boosting well upto 10 psi and holding at around 7 now i know the general rule is green spring for unmapped and yellow for mapped but my question is would leaving the yellow spring in, would it cause any problems with my car not being mapped?  :undecided:
Current - MK6 GTi Edition 35 - Candy White - 3 door
jamie16v
Re: Question about green spring vs yellow
« Reply #1 on: 03 June 2013, 13:05 »
what its holding with the yellow spring atm seems about right for an unmappe car, it seems that air was getting past with a green spring  :tongue:
Offline Nino
« Reply #2 on: 03 June 2013, 13:06 »
So by that I assume its safe to leave the yellow one on then?
Hmmm I wonder if that's why my 17705 kept coming back, but this is my 3rd DV  :undecided:
Offline GTi_James
« Reply #3 on: 03 June 2013, 13:27 »
it should be 10psi for unmapped, mine peaks a bit higher but levels off at about 7 or 8
Offline Nino
« Reply #4 on: 03 June 2013, 21:07 »
Anyone able to confirm if it will be ok?
« Reply #5 on: 03 June 2013, 21:10 »
I ran a yellow spring in my Octavia vRs on a standard map all ok for few weeks.
Offline Nino
« Reply #6 on: 03 June 2013, 21:14 »
What happened after a few weeks?!  :undecided:
« Reply #7 on: 03 June 2013, 21:15 »
It was remapped, it is not going to hurt on a yellow spring
jamie16v
« Reply #8 on: 03 June 2013, 21:19 »
i ran a blue spring for a while on a stage one map, albeit until i took it gor a custom stage 2 map and nick swapped it for a yellow..lol
Offline Nino
« Reply #9 on: 03 June 2013, 23:54 »
Thanks guys :)
