Author Topic: rtech..  (Read 2655 times)
Offline barrym381
Re: rtech..
« Reply #10 on: 03 June 2013, 17:33 »
you should be glad they said a week rather than just popping any old map on an your car going boom shortly after  :wink: and im sure they have done enough 1.8ts to know what they are doing
Yeqh i know mate, best in the business aint they..just a weeks a long time with no car aha
i know i dropped mine at them saturday morning after a long drive  :grin:
Offline dom
  • Back in a Mk4
Re: rtech..
« Reply #11 on: 03 June 2013, 17:36 »
I'd seriously reconsider not doing maf, injectors and fmic, I bet you'll end up doing them eventually then you'll need it mapped again :wink:
Offline kingaz
Re: rtech..
« Reply #12 on: 03 June 2013, 17:51 »
Yeah i understand what ur saying, but im talkin this time next year ill be doing a revamp. Money could go into other things atm, bodywork, interior etc
Offline topher
  • Administrator
  • fully functioning
Re: rtech..
« Reply #13 on: 03 June 2013, 19:12 »
Plus theres a bit of controversary around the turbo..sum people sayin its a knock off and others sayin its a hybrid.. ita got ten blades
i've seen a few of those 10 blade chinese "hybrids" that struggle to make more than 210bhp
Offline Scott D
Re: rtech..
« Reply #14 on: 03 June 2013, 19:25 »
If yours is a AGU you'll need bigger MAF and injectors as IIRC 230bhp is the limit possibably fuel pump as well
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline kingaz
Re: rtech..
« Reply #15 on: 03 June 2013, 19:53 »
Yeah but the chinese ones r different. This onea part number matches up as a k03s. Iv got a pic if that helps?
And 230bhp is ample mate
jamie16v
Re: rtech..
« Reply #16 on: 03 June 2013, 19:59 »
got a few pics of the turbo?
my turbo is a chinese "knock off" but it`s working ok, its not the 10 blade one though. it appears to have a k04-023 turbine wheel and i beleive the turbine is k04 too judging by the size.
it would be interesting to see what your turbo does actually do. where did you get it by the way?
Offline davemk4
Re: rtech..
« Reply #17 on: 03 June 2013, 20:00 »
id defo atleasts fit a fmic as mine suffers heat soak on a generic stage 1 now...... id dread the heat issues on 230bhp on a stock side mount
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline kingaz
Re: rtech..
« Reply #18 on: 03 June 2013, 20:02 »
Its not stock its one of them thicker alloy ones
jamie16v
Re: rtech..
« Reply #19 on: 03 June 2013, 20:07 »
regardless, it`s not getting any airflow being a sidemount.. that`s why we specify a front mount!
