Author Topic: Engine Problem!!!  (Read 1753 times)
Offline budgie
Engine Problem!!!
« on: 03 June 2013, 09:15 »
was taking the other half to collage and all of a suden the car just died :sad:  started it up again and the revs was going up and down slightly, no overheating or anything either, any ideas people??
Offline Scott-R
  • GoT BoosT!
Re: Engine Problem!!!
« Reply #1 on: 03 June 2013, 09:30 »
I was in Aberdeen not too long ago with my vagcom... Buggery.
Coil packs?
Golf GTI ... What else would you have?
Offline budgie
« Reply #2 on: 03 June 2013, 10:12 »
how do i check them? put it in the easiest way possible as im not mechanicly headed and dont want to mess up somthing else, :sad:
Offline asboGTI
« Reply #3 on: 03 June 2013, 10:16 »
look in this thread i think dalo put it up how to check
http://www.golfgtiforum.co.uk/index.php?topic=254665.0
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline budgie
« Reply #4 on: 03 June 2013, 10:20 »
thanks. its a aum 2002 engine so im hoping its just that, just completetly died and when restarted the revs was flutering a bit. :angry:
Offline asboGTI
« Reply #5 on: 03 June 2013, 10:23 »
as said try and get it scanned using vag com or a cheap code reader off the bay
Offline budgie
« Reply #6 on: 03 June 2013, 10:27 »
just went out to the car and realised a pudle underneath, :angry:. looks like just water???
Offline Nino
« Reply #7 on: 03 June 2013, 10:35 »
smell it, or taste it? your radiator may have a hole init or check (looking from the frount of your car) the bottom right hand side of the rad, there is a drainage tap that may of come loose?
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline budgie
« Reply #8 on: 03 June 2013, 10:38 »
hasnt got a smell to it, 1st thing i did was put finger in it. its more at the back of the engine
Offline budgie
« Reply #9 on: 03 June 2013, 11:17 »
unpluged 3 of the 4 coil packs, when i unpluged them one at a time on everyone the car idled at 800rpm no problem but when i put plugs back in it started to waver between 600 and 800, havnt checked the last one yet as its under somthing? any clues now?
