Author Topic: turbo question  (Read 2493 times)
Offline Rockey5uk2001
turbo question
« on: 02 June 2013, 17:50 »
Bit of a problem with the gti
When accelerating it hesitates for a second seems
To of worsted after a flat battery any suggestions
Offline rio_gti
Re: turbo question
« Reply #1 on: 02 June 2013, 17:54 »
N75 valve playing up?
Offline Scott-R
  • GoT BoosT!
Re: turbo question
« Reply #2 on: 02 June 2013, 18:03 »
Is that.. Started after a flat battery?
Golf GTI ... What else would you have?
Re: turbo question
« Reply #3 on: 02 June 2013, 19:00 »
Whats the n75 valve no just worst after battery
jamie16v
Re: turbo question
« Reply #4 on: 02 June 2013, 19:29 »
try cleaning the throttle body and do a re-align on the throttle body too, there are guides on here!
also if youre battery has been low you may have fault codes stored on the ecu which may need clearing.
« Last Edit: 02 June 2013, 21:56 by jamie16v »
Offline rio_gti
Re: turbo question
« Reply #5 on: 02 June 2013, 19:34 »
try cleaning the throttle body and do a re-aling on the throttle body too, there are guides on here!
This also  :smiley:
Re: turbo question
« Reply #6 on: 02 June 2013, 19:43 »
i killed the battery by leaving the lights on :(
Re: turbo question
« Reply #7 on: 02 June 2013, 19:50 »
cant find a guide =/
Offline Rhyso
Re: turbo question
« Reply #9 on: 02 June 2013, 20:14 »
