Author Topic: Mk2 owners opinions needed please.  (Read 7652 times)
VW BUSH
Re: Mk2 owners opinions needed please.
« Reply #30 on: 02 June 2013, 15:54 »
Both engines are very strong.  One doesn't have enough valves.  The other has an accident waiting to happen attached to it.
They sure do, less forgiving than a roly poly Mk3 with abs.
Everything about a Mk2 16v is spanking it to the limiter, if you drive it daily this will become a problem unless you are Mother Theresa.
Offline Diamond Hell
  • Opinions я Us
« Reply #31 on: 03 June 2013, 14:42 »
Is this the crunchy second gear that gets mentioned in several adverts, and is it that serious?
No - it's the K-Jet injection system - tends to run lean at high revs, meaning if you do it enough times you're likely to grenade the motor.... or it'll go out of adjustment and grenade the motor.
Gavv8
« Reply #32 on: 03 June 2013, 19:47 »
Is it the same system on the 8v and 16v? as i would have thought the 8v would encourage gentler driving , every article i read about the mk2 16v describes how much fun it is to rag.
Offline Sgt_Lemon
  • 8v owners club
« Reply #33 on: 03 June 2013, 20:10 »
Both fun to rag, the 16v just has so much more at the higher revs. 8v feels it has more torque at the lower end.
Offline robiwill
« Reply #34 on: 03 June 2013, 21:35 »
Personal view would be to get an 8v as uses a lot less fuel and the pb engine is alot less prone to issues. second gear crunch is a common issue can be improved by using a mk3 weighted gearshift rod. also a very common gearbox to replace as the same in all mk3 1.8 golfs. But as said before buy on shell condition. I have found through yrs of buying them and in the distant past breaking them that 5drs tend to be in more original condition and also cheaper but more practical as a daily. If you do get an 8v I would suggest upgrading the brakes and which ever golf the headlight loom. Good luck with your search. Mileage pah had several mk2 golfs pushing 250K so how it sounds is key and certainly from cold
Gavv8
« Reply #35 on: 04 June 2013, 06:20 »
Thanks for all the feedback as this is helping me to come to the right decision, for now i'm going to concentrate on the 8v as i think i have a better chance of getting a good usable one around my budget.
  • Opinions я Us
« Reply #36 on: 04 June 2013, 07:47 »
Up to 86 the 8v ran on k-jet. After that it changed to Digifant which is an electronic injection system and should be more reliable - although it's still pretty basic. There are many reasons people fit ABFs from the Golf3 - the better management is a key one of these.  As an example Dannyp did a brim to brim on the run back from Germany and saw 40mpg. What's not to like about that?
Gavv8
« Reply #37 on: 04 June 2013, 18:51 »
I was going to look at an abf'd mk2 three door but it's been lowered etc and i don't want to go down that road again...then this popped up on ebay.. :drool:
http://www.ebay.co.uk/itm/1988-VOLKSWAGEN-GOLF-MK2-GTI-OAK-GREEN-CAMPAIGN-GOLF-IN-TEN-MILLION-1-0F-300-/221235644879?pt=Automobiles_UK&hash=item3382ac09cf
