Author Topic: AGU stuttering under boost  (Read 2365 times)
Offline ReadieeVTS
« on: 31 May 2013, 22:08 »
Hi guys, so I've got a slight problem with the new car...as soon as I hit 0.5 bar of boost it will stutter/misfire like a muthaf**ker, I've changed the plugs and it's still the same, it's had 2 new coil packs on but I think there cheapies as they aren't branded etc. it will stutter a bit when in 2nd-5th gear at low revs when driven normally, I can't connect it up to a obd scanner as my one says that there "no communication found" help me guys lol
Offline barrym381
Re: AGU stuttering under boost
« Reply #1 on: 31 May 2013, 23:19 »
ignition amp i would be looking at as coil-packs on the agu very rarely fail  :smiley:
Offline ReadieeVTS
« Reply #2 on: 01 June 2013, 00:18 »
yeah that's what I was reading, just wish my obd port was working!! maybe it could of narrowed things down for me but nope! :(
Offline ReadieeVTS
« Reply #3 on: 01 June 2013, 13:22 »
Update: just bought a ignition amp and its still the same  :angry:
Offline ReadieeVTS
« Reply #4 on: 01 June 2013, 14:22 »
my mate managed to get vagcom on it and it said MAF meter signal input too low/ intermittent.
I Have however run the car with maf unplugged and its still the same :( im lost!!
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 01 June 2013, 15:41 »
could be a weak fuel pump not flowing enough to make a nice rich mixture under load, need to get your fuelling checked
Offline ReadieeVTS
« Reply #6 on: 01 June 2013, 17:29 »
whats the best way of checking that pal?
Offline ReadieeVTS
« Reply #8 on: 02 June 2013, 10:22 »
that's more expensive than a new pump LOL
