Golf mk3
hardmonkeys
Hot golf
Topic: Hot golf (Read 2420 times)
richyrooney
Hot golf
31 May 2013, 20:47 »
My girlfriend who borrowed my car today brought it back saying it had a burning smell....went out and the car temp was hot by this I mean I opened the bonnet and the thing was about to overheat badly, opened the cap on the header tank (slowly) and it started to gush.Fan wasn't going so my immediate thought is it must be the fan switch in the rad shorted the switch and the fan spins.......but the temp gauge on the dashboard through all of this was just sat in the middle (needle pointing straight up) don't understand any thoughts?
?apart from don't lend her your car again (97 16v)
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Hot golf
31 May 2013, 20:53 »
water pump working?
richyrooney
Re: Hot golf
31 May 2013, 20:59 »
Changed the water pump about 5 months ago would that explain the temp gauge only showing half?
itavaltalainen
Re: Hot golf
31 May 2013, 21:13 »
are the hoses to rad both getting hot?
also check the temp sender. could be off...
http://www.motor-talk.de/forum/aktion/Attachment.html?attachmentId=719242
but would be weird for that and fan switch in radiator both going wrong at the same time. fan should come on regardless of what temp sender for ecu/dash senses.
richyrooney
Re: Hot golf
31 May 2013, 21:27 »
Just been out to the car the top hose is a lot hotter than the bottom one is this a naffed water pump indicator??
itavaltalainen
Re: Hot golf
31 May 2013, 21:30 »
is the water pump running the right way round?? you can put it the wrong way round on the 1.8/2.0 mk3 engines (incl the 16v 2.0)
which side of the belt drives the pump pulley?
richyrooney
Re: Hot golf
Reply #6 on:
31 May 2013, 21:41 »
The grooved side of the belt is running in the grooves on the pump pulley dont think its this the cars been running tip top until today just dont understand why the fan didnt cut in as the switch is in the top of the rad?
richyrooney
Re: Hot golf
Reply #7 on:
01 June 2013, 12:32 »
Took car out for little spin this morning and when I got back bottom hose cold top hose hot, the heater is working which leads me to believe the water pump is working so think the thermostat is buggered just bought one so will have to see
itavaltalainen
Re: Hot golf
Reply #8 on:
01 June 2013, 12:49 »
not necessarily thermostat, if thermostat is broken it would go well over 90. unless the temp sender is broken.... measure it!
richyrooney
Re: Hot golf
Reply #9 on:
02 June 2013, 20:32 »
Temp sender is another days worry am going to change the thermostat tomorrow been a while since i did the water pump so can remember but can the thermostat be changed without removing the pump know its in a plastic housing but can't recall if you can change it in situ.........anyone remember its a 2.0abf
Golf mk3
hardmonkeys
Hot golf
