Author Topic: no noise ?  (Read 2334 times)
Offline welshdean
no noise ?
« on: 31 May 2013, 15:01 »
I've received my forge diverter valve today and it's fully functioning with green spring inside.
I've put the dv on all pipes and it's sitting snug and tight with everything done up as it should be.
However, when changing gears and even revving th car, there's no noise (tsshhh).
The engine code is agu (1999)
 Can anybody tell me why it's not making the noise as when it's dumping air
Offline barrym381
Re: no noise ?
« Reply #1 on: 31 May 2013, 15:11 »
its a recirculating d/v the forge so sends the air back into the system not like an atmospheric 1
Offline nickellis1
Re: no noise ?
« Reply #2 on: 31 May 2013, 15:29 »
I smoothed my airbox and drilled the right hand top corner and fitted a green panel and ran a forge tip.
Gave a really loud pshhhh noise :-) :-) sounded like an atmospheric
Offline welshdean
Re: no noise ?
« Reply #3 on: 31 May 2013, 15:35 »
Ok, so what's my beat way to get the noise ? I've got a cone filter that was given to me , it was used on a vectra 24v.  Would it be any good for ny car it's a bit dirty at the moment but could be cleaned up. It's got some outer plastic cone around it aswell
Offline nickellis1
Re: no noise ?
« Reply #4 on: 31 May 2013, 15:52 »
You will get more of a dumping noise with it being an open filter, but unless you get a proper heat shield you will start to suck in hot air which will result in less power
Offline golfyste
  • Project track car
Re: no noise ?
« Reply #5 on: 31 May 2013, 20:00 »
As above, you need a upgraded filter of some sort.
Most noise comes from at open cone with a cai
But just get a panel filer and cold air feed and you should be satisfied.
Offline james2
  • No scammers please.
Re: no noise ?
« Reply #6 on: 31 May 2013, 20:13 »
get it remapped it sounds  :cool:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Nino
Re: no noise ?
« Reply #7 on: 31 May 2013, 21:21 »
He brought it up to me and I checked all his pipes and everything is how it should be. Just for good measure I even fitted my DV (007p) because I know mine makes the noise and nothing at all not even a peep. I'm abit confused for him as for a test we undid the air box so it would act as if its an open air and it still didn't make a peep yet my car (AUM) with my RAMAIR fitted makes quite a loud tsssssh.
Current - MK6 GTi Edition 35 - Candy White - 3 door
jamie16v
Re: no noise ?
« Reply #8 on: 31 May 2013, 21:35 »
are any of his vac hoses leaking? or, are you getting any boost?.  :undecided:
« Last Edit: 31 May 2013, 21:44 by jamie16v »
Offline Nino
Re: no noise ?
« Reply #9 on: 31 May 2013, 22:43 »
No leaks codes when scanned.  But his car does feel slower than mine but I put that down to I have changed every pipe to silicone on mine and I have the KO3s but I think he has the KO3
