Author Topic: Mk3 Golf 1.8 8Valve codes  (Read 6108 times)
Offline DCmk3
« on: 30 May 2013, 16:39 »
So I have been noticing the same codes coming up over and over but I can't seem to find out what is causing the codes..
It's a 97 1.8i 8valve motor.
At first I was getting the error code;
00527 - Intake Manifold Temperature Sensor (G72)
30-10 - Open or Short to B+ - Intermittent
I tried clearing the codes and a few days later I had the same code again, so which sensor is it that is playing up? Because I can't seem to find out which sensor it is or where it is located.
Now I am also recieving the following code;
00519 - Intake Manifold Pressure Sensor (G71)
29-10 - Short to Ground - Intermittent.
Are both of those readings from the MAP Sensor or is it something else?
2014 Mk7 GTI - Littco L500
