Golf mk4
Wazzzer
how to remove inner ultasonic alarm thing bulbs
Topic: how to remove inner ultasonic alarm thing bulbs (Read 799 times)
davemk4
30 May 2013, 14:03 »
Cant find 1 how tp remove the unit to get to bulb
2. What bulb it takes
It the 2 inner side lights with alarm sensors in it....
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
GTi_James
Re: how to remove inner ultasonic alarm thing bulbs
30 May 2013, 16:58 »
if your looking at it from the front seat its easier, insert a flat head into the side facing the windscreen and leaver out, should be a simple enough job bud
davemk4
30 May 2013, 18:51 »
Thank you
Golf mk4
Wazzzer
