Author Topic: forge 007p revised piston kit  (Read 3085 times)
Offline mar_k
Re: forge 007p revised piston kit
« Reply #10 on: 31 May 2013, 20:38 »
say you have pressurised the system with a compressor to (rated spings psi), youve removed the DV from the TIP (but still bonnected to boost pipe) and can feel air leeking to the tip..
though, i disagree with what you are doing guys, soon forge will get wise to people taking the piss, forge are expensive enough, you should have to pay when things really do go wrong!.
then i suppose if they dropped their prices a little their customer services would deteriorate too. :undecided:
The old type piston leaked no matter what so in my opinion its not fit for use,
I don't see why I should pay £14 for a rebuild kit with the revised piston design as I had only recently paid £117 for
the valve.
I now have £14 to spend of something else.
Their customer service is excellent and they recognize they had an issue with the old piston design,
jamie16v
« Reply #11 on: 31 May 2013, 21:09 »
i meant it for people who are just taking the piss! :wink:
Offline davemk4
« Reply #12 on: 31 May 2013, 22:25 »
this is it i bought the valve used and unkown age so serviced it i wasnt going to complain. the results are worth the 14 quid the car drives superb oh and by the way DYNO time this sunday so it will be the first time to see what all these mods have done to a 120k 10 year old car
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Dalo Harkin
« Reply #13 on: 02 June 2013, 10:00 »
open your DV - if its the old dome one get the kit, if its flat at the bottom - don't bother!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 02 June 2013, 11:13 »
I've got the dome version in mine, will be on the phone to them tomorrow to get the info on it. Don't mind paying for it...
Offline 1 gti
« Reply #15 on: 06 June 2013, 19:29 »
Is it straight forward to change the piston and seals? Haven't looked at mine yet
Offline davemk4
« Reply #16 on: 06 June 2013, 20:05 »
took 10 mins it easy and obv where goes where  :smiley:
