Author Topic: What do i need in total ?  (Read 1468 times)
Offline welshdean
« on: 29 May 2013, 21:05 »
ok, so im going to get my thermostat replaced on saturday and taking the advice of people from the forum, im also going to replace the temp sender and coolant.
ive read somewhere some time ago that you need to ideally replace the rubber O rings with the temp sender or something like that.
can anybody tell me exactly what i need to buy in total as i dont want to go out and buy a few bits and pieces and think... " i should have bought one of those "
Offline gm8
Offline barrym381
Re: What do i need in total ?
« Reply #2 on: 29 May 2013, 21:13 »
Offline welshdean
« Reply #3 on: 29 May 2013, 22:15 »
I'm going to get the guy to drain all the old coolant anyway and get a nice fresh batch in there
Offline Nino
« Reply #4 on: 29 May 2013, 23:17 »
Go to VW and buy two bottles of g13, that's the new g12  :wink:
Current - MK6 GTi Edition 35
Offline welshdean
« Reply #5 on: 30 May 2013, 15:22 »
Do I need a rubber o ring for the temp sender aswell as one for the thermostat. Also the guy said that if I'm replacing the thermostat , temp sender and coolant, I might aswell replace the rad switch.
What is the rad switch and do I need to replace it ?
Offline welshdean
« Reply #6 on: 30 May 2013, 19:44 »
Bump :wink:
Offline barrym381
« Reply #7 on: 30 May 2013, 19:50 »
no you dont need a rad switch unless the fans dont work  :smiley:
Offline welshdean
« Reply #8 on: 30 May 2013, 20:02 »
Thanks for the reply barrym381.
Saves me a couple of quid atleast
