Author Topic: Another door lock module question sorry guys  (Read 1855 times)
Offline cooki
  • 1.8T AUM
« on: 29 May 2013, 20:50 »
I've tried searching but no joy there's just too many posts to search through.
Simple question I no it will be a 1 word answer but do u need to recode the drivers side door lock module to the car one fitting a second hand module??
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline gm8
Re: Another door lock module question sorry guys
« Reply #1 on: 29 May 2013, 20:52 »
I would doubt it , the only electrics inside are microswitches and PCB wiring
Offline davemk4
« Reply #2 on: 29 May 2013, 20:52 »
no dont think so we about to do mine with a new one from VW and as far as im aware it just a straight swap
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline gm8
« Reply #3 on: 29 May 2013, 20:54 »
they are pretty easy to DIY repair guys, just trying to save you some £££
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 29 May 2013, 20:58 »
no coding needed with mk4 door locks, its all done in the ccm
jamie16v
« Reply #5 on: 29 May 2013, 21:05 »
To be honest a second hand module is probaly going to have or at least end up with the same problem.
youre better off opening up yours and re-soldering the dodgy dry joints.
Offline cooki
  • 1.8T AUM
« Reply #6 on: 29 May 2013, 21:08 »
Thanks guys was just checking u see as I had a second hand one fitted the other day but all my Symptoms  are the same so I'm guessing the one that's been fitted was also faulty.
Thinking of fitting another one that's new or guaranteed working b4 I try the CCM as that does need coding I think.
jamie16v
« Reply #7 on: 29 May 2013, 21:18 »
how do you know the CCM needs coding?
Offline cooki
  • 1.8T AUM
« Reply #8 on: 29 May 2013, 21:52 »
Good question mate just think I've seen it needs coding on this forum over the years. Correct me if I'm wrong???
jamie16v
« Reply #9 on: 29 May 2013, 22:15 »
Dont think so, not  unless youre putting a new one in etc..
if youre just changing the door module then you dont have to touch the ccm.
just take out the door module, and take apart and follow the how to in the maintenance and  info section!
