Author Topic: Bluetooth Coding  (Read 8399 times)
Offline Eeef
  • Lord of War
Bluetooth Coding
« on: 29 May 2013, 20:21 »
Plugged myself into the car for half an hour and set Fogs as DRLS and enabled needle sweep.
However, when I came to code the Bluetooth/phone in preparation for the install I seemed to be missing a load of bytes?
Mine
P3eps'
Any ideas?
Offline mike.
Re: Bluetooth Coding
« Reply #1 on: 29 May 2013, 21:28 »
Your CAN gateway 7N0907530C is the updated version of P3EPS 1K0907530AD
Are you running the latest version of VCDS, if not, try the BETA version as it looks like they don't have enough information about your new module in the version you are running.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Obbzi
« Reply #2 on: 29 May 2013, 21:41 »
Mike you seem clued up :smiley:where a outs are you located please?
2008 R32 DBP gone. 2008 GT TDI going 2009 GTI coming soon!
Offline mike.
« Reply #3 on: 29 May 2013, 21:44 »
Northern Ireland, not so local  :sad:
Offline Obbzi
« Reply #4 on: 29 May 2013, 22:20 »
D'oh  :cry: Not having much luck with anyonenear to me with Vag Com, looks like I might have to got o the dealers  :cry:
Offline Eeef
  • Lord of War
« Reply #5 on: 29 May 2013, 22:24 »
Thanks Mike. I'm on 10.6.4 so i'll give it an update and try again.
Marshy
« Reply #6 on: 29 May 2013, 22:52 »
I get that sometimes when coding it says no long code helper or there bytes missing like you say.
Usually if I come out of that control unit and go back in it works perfectly with all the options.
I'm assuming you've tried more than once?
Offline Keithuk
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline Eeef
  • Lord of War
« Reply #8 on: 30 May 2013, 08:11 »
Tried it a few times, and have now upgraded to 11.11.2, but still have the same issue.  :sad:
Offline AndyG
« Reply #9 on: 30 May 2013, 08:26 »
Obbzi,try VAG Bolton for any vagcom coding.They are a local independent VW/Audi garage and a good set of guys.They be cheaper than Smith Knight Fay for out you want doing.Its only in Kearsley just down road from you.
Golf 7R,DSG,5 door White,leather,rear camera.
