Author Topic: Bonnet sound deadening?  (Read 3021 times)
Offline madsb
« on: 29 May 2013, 13:30 »
Bonnet sound deadening? Any recommendations? Which material? ebay, amazon links? :) would rather have new stuff than go to the scrappy.
Cheers.
Offline itavaltalainen
Re: Bonnet sound deadening?
« Reply #1 on: 29 May 2013, 13:54 »
get the mats from a diesel, straight fit with no messing around and probably best sound deadening too.
Offline Foreveryoungaus16v
« Reply #2 on: 29 May 2013, 13:55 »
Binned mine.  Looked sh!t and did not notice difference
163 BHP (TSR POWER RUN)
Offline tweed
« Reply #3 on: 29 May 2013, 13:59 »
I cant see how that will work. You sure its not insulation?
I work on sites and sometimes my job is to make sure the internal walls make the dB levels etc. Boring crap.
Anyway what ever you put under the bonnet wont do anything as engine noise will just bounce off the road. It wont do anything for inside the car. So its not worth doing mate
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 29 May 2013, 14:19 »
Although coupled with a TDI/16v engine undertray may make the tiniest bit of difference. Mine came with both as standard but I'm sceptical.
Offline madsb
« Reply #5 on: 29 May 2013, 14:55 »
Ah... Maybe some on the firewall though? Would that help? Or is it already covered? Probably gonna do the benches and boot with some 2 mm silent coat
« Reply #6 on: 29 May 2013, 14:57 »
Its not worth doing!
« Reply #7 on: 29 May 2013, 15:16 »
Firewall would be worth doing along with the rest of the interior. I need to get some Silent coat for mine as the older I get the less tolerant I'm getting with excess wind and road noise.
Offline Screech16v
  • MK3 20vt AGU
« Reply #8 on: 29 May 2013, 18:16 »
I removed mine last week as my filter is in a sh!te place at the mo and the sound deadening was effectively blocking some of the air flow to it.Engine noise is slightly louder especially the 008, its starting to annoy me PTSSSSH  :grin:
On the plus I think it will be slightly cooler in the bay and it looks cleaner.
Offline Len
« Reply #9 on: 30 May 2013, 13:21 »
Standard Gti sound deadening is good
www.sas.org.uk
www.the-ace.org.uk
