Author Topic: oooppss  (Read 2987 times)
Offline davemk4
Re: oooppss
« Reply #10 on: 30 May 2013, 19:34 »
bet that was embarssing gas the 172 flew back past ya. used an item once like this on my last car it was great and sounded good but just didnt feel right so took it off
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline topher
  • Administrator
  • fully functioning
Re: oooppss
« Reply #11 on: 31 May 2013, 19:31 »
What happened in that picture? The crank snap and piston push through the block? I don't follow  :embarrassed:
#3 rod snapped, still attached to the crank so it bashed f*ck out of both sides of the block and the sump. I like how you can see straight through it that's why i snapped the picture :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: oooppss
« Reply #12 on: 01 June 2013, 10:48 »
safe to say you won't be using any parts out of that engine lol
Offline topher
  • Administrator
  • fully functioning
Re: oooppss
« Reply #13 on: 01 June 2013, 15:39 »
bit of liquid metal it'll be alright :grin:
Offline Scott-R
  • GoT BoosT!
Re: oooppss
« Reply #14 on: 02 June 2013, 15:35 »
Not good, next time take some advice from the forums buddy
 :embarrassed:
Golf GTI ... What else would you have?
