Author Topic: adding G60 to a k-jet 8v  (Read 2171 times)
Offline Dizzie
  • Make friends with your fast
« on: 13 October 2003, 20:52 »
can I just add the charger + various pipes and an intercooler and have a superchargered car?
can u add a dump valve?
is there anything else I need to know? I guess I have to lower the compression?
Offline tinman
Re:adding G60 to a k-jet 8v
« Reply #1 on: 14 October 2003, 12:24 »
As a guess - theoretically yes, but in practise you wouldn't want to try it.
I believe the G60 block is the same, and the head is 8v, but I would reckon thats about where the similarities end.
It would be easier to find a G60 from a broken Corrado. They are around.
Tin
« Last Edit: 14 October 2003, 12:24 by tinman »
Offline Dizzie
« Reply #2 on: 14 October 2003, 13:04 »
yeah I was thinking that route after talking to a few people about it and I'd need to upgrade lots of other bits.
Can I use my existing loom, etc from the K-jet if I got a G60 from a corrado do you know?
cheers.
Offline mk1
« Reply #3 on: 14 October 2003, 22:27 »
G60 fuel injection is totaly different,you will need the ECU, injectors, harness, etc, etc. :-\
