Author Topic: HELP! All brakes locked on!  (Read 1492 times)
billabong
« on: 28 May 2013, 10:13 »
Yesterday I upgraded the brakes on my 1.9D Mk3 golf to GTI brakes.
I used the GTI wishbones, hubs,driveshafts, carriers, calipers, discs and pads. I also put the GTI master cylinder on.
I did a full bleed and tested, all seemed OK but the pedal was a bit hard.
This morning driving to work, after about 10 miles, all the brakes seized on and now the car is at a standstill and will not move at all!
This doesnt make any sense? :/ Any ideas please??
Offline Bellend
Re: HELP! All brakes locked on!
« Reply #1 on: 28 May 2013, 10:42 »
Master cylinder damaged in some way or incorrectly fitted if it's definitely all brakes.
Where all my moneys went.
billabong
« Reply #2 on: 28 May 2013, 10:46 »
Thanks.
What MC should I be using? The GTI one was a car with ABS, will that make a difference?
The original MC was a 20 and the GTI was a 23 I think...
Thanks
Offline Bellend
« Reply #3 on: 28 May 2013, 10:48 »
I don't think it would tbh but you can use your old MC no problems, I used my old one which I think was 20 or 19 IIRC when I upgraded and brakes were good and sharp and never had any issues.
billabong
« Reply #4 on: 28 May 2013, 10:57 »
Ah ok, Maybe I will put the old one back on and do a full bleed and see how that goes...
I had to bend the pipes to get it to fit the 23 so hopefully they will bend back ok!
Offline Bellend
« Reply #5 on: 28 May 2013, 11:02 »
Ah.
How badly bent are they? Not kinked in any way?
Leave the car a while, I wonder if the brakes will release?
Could well be the pipes kinked and you've forced fluid through with help of a servo and it doesn't quite have the pressure to release the other way.
Check the pipes.
billabong
« Reply #6 on: 28 May 2013, 11:35 »
Pretty sure none kinked but can check. Going to try again soon to see if it has unstuck. If not I'll get the AA to run me home :/
