Author Topic: pcv simplification  (Read 6462 times)
jamie16v
Re: pcv simplification
« Reply #10 on: 06 June 2013, 16:34 »
oh right my bad.... and just re read it.........
lol, only just realised this thread had a reply, thanks rio.
i`m going to use that nipple to feed boost to the N75, it does work trust me  :wink:
what did you use to block the check valve underneath?..
you remove the check valve completely!!!
yes, you remove the check valve, but what did you plug that gaping hole with lol.
i was looking at 25mm alloy blanking plugs or simular?
Offline rio_gti
« Reply #11 on: 06 June 2013, 17:05 »
think i may be confused!!!! post a pic of what your on about   :laugh:
Offline Dave_IOW
« Reply #12 on: 07 June 2013, 01:03 »
No need to keep the valve once you've removed all the pipes mate.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
jamie16v
« Reply #13 on: 07 June 2013, 09:25 »
lol, my god people  :grin: youre not getting my question....  :evil:
i have now blocked the valve and removed the pipework, for now i have blocked off the valve with a bit of pipe with a bolt stuck in the end of it.
untill i can get a blanking cap, thats how its staying..lol :smiley:
Offline GTi_James
« Reply #14 on: 07 June 2013, 11:04 »
... well why didnt you say that in the first place!  :lipsrsealed:  :laugh:
jamie16v
« Reply #15 on: 07 June 2013, 11:08 »
lol..grrrrrrrrrrrr  :angry:  :grin:
because i didnt block it off at first.. i was asking how others has removed theirs (check valve), bypass with a straight bit of pipe or put i blanking cap in the hole where the check valve was?
Offline GTi_James
« Reply #16 on: 07 June 2013, 11:33 »
...my brain hurts, the only valves i have are the hocky puck which is going bye-bye when i fit the new TIP and the one that use to connect the mani and brake pressure line i believe
jamie16v
« Reply #17 on: 07 June 2013, 11:56 »
there is a check valve in the pipework blelow the manifold. it stops boost pressure from entering the bottom end.. you`ll probably find it hiding in a T-peice, i replaced it before now on suspect it may have been leaking.
