Author Topic: Urgent help needed :(  (Read 3088 times)
Offline rfn_hodgson
« on: 27 May 2013, 05:29 »
Just been going along the motorway and the car has started to shudder in the lower rev range?
Traction light has come on solid,
The power is still there, am I right in thinking its the gear box or clutch?
Gt tdi 150. 02 plate
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Urgent help needed :(
« Reply #1 on: 27 May 2013, 07:53 »
Boost pipe? Have a look under the hood for anything not normal then get it scanned!
Sticky turbo... :undecided:
Offline Rhyso
« Reply #2 on: 27 May 2013, 08:39 »
MAF. Try unplugging it and go for a drive. If it drives fine then your MAF is shot
Offline rfn_hodgson
« Reply #3 on: 27 May 2013, 09:44 »
ok bit of an update it seemed to shudder under load and when i mean shudder i mean the whole car shudders :/ .... putting a bit of toe into the accelerator pedal.
i got back to camp and turned the engine off had a look in the engine bay and no signs of smoke or steam.
turned the engine back on and took it round the car park and what do you know FINE!!
rhyso and scarr88 could could this be anything to do with your ideas??
Offline Rhyso
« Reply #4 on: 27 May 2013, 10:26 »
Sounds like you hit limp mode  :undecided:
The fact it resets after you cycle the ignition suggests you have a faulty sensor. Best get it scanned as it will have thrown a code
Offline rfn_hodgson
« Reply #5 on: 27 May 2013, 12:31 »
cheers for that buddy
Offline rfn_hodgson
« Reply #6 on: 27 May 2013, 20:45 »
Hello again just a slight update....
I drove it again and fine up until 20 mile into the journey and it happened again so I unplugged the MAF and no power but the shuddering stopped for a while then came back.
I then pulled over and plugged it back in and it's been ok for the rest of the journey 30 mile ish
I can't plug it in at the moment but I'm working on getting it sorted
Any more ideas or still the same ??
