Author Topic: Tyre question  (Read 4448 times)
Offline Mark b
Tyre question
« on: 27 May 2013, 00:28 »
On my car my tyres at the mo are 225/40/18 could I also use 225/45/18 and what the difference between the 2
Standard gti 2.0 115bhp 2000 w reg
Offline Seanl
Offline gm8
Re: Tyre question
« Reply #2 on: 27 May 2013, 19:56 »
the difference is the profile size 45 is bigger/higher
Re: Tyre question
« Reply #3 on: 27 May 2013, 20:21 »
225/40/18's are needed to keep the gearing / speedo correct.
Offline dom
  • Back in a Mk4
Re: Tyre question
« Reply #4 on: 27 May 2013, 21:02 »
This, your speedo will be out by a few mph at 60.
Offline Mark b
Re: Tyre question
« Reply #5 on: 27 May 2013, 23:04 »
Cheers Wayne ill keep to those then :-)
When I go over 60 I get some vibration on the steering wheel would it be the tracking or balancing
Re: Tyre question
« Reply #6 on: 27 May 2013, 23:48 »
Balancing or missing spiggot rings
Offline Mark b
Re: Tyre question
« Reply #7 on: 28 May 2013, 00:27 »
When I put the alloys on they fitted snug on the hub should I but some rings anyway ? As ill be replacing all the tyres soon and they will get balanced when I get them fitted
Re: Tyre question
« Reply #8 on: 28 May 2013, 10:54 »
If they are a tight fit on the hub that is what really matters, so no spiggot rings needed.
Offline Mark b
Re: Tyre question
« Reply #9 on: 28 May 2013, 12:50 »
The alloys fitted straight as they came off another mk4 golf so do you think it'll be the balacing or tracking as my car does drift slightly to the left when I let go of the wheel
