Author Topic: What's the best mods to improve the handling?  (Read 3186 times)
Offline Rgdogg
« on: 26 May 2013, 22:15 »
As it says! I have a standard gti except for a bluefin that's getting installed on Tuesday, but even without that last night I had a little one on one with a cooper s, I was doing ok in a straight line pulling away comfortably, but the problem was stopping and cornering, it was all over the place, I was going to get some eibach sportlines but somehow this may not be adequate! Any other ideas as I don't really want to go the coil over way? Thanks
Gti, Candy White, 3door, DSG, Leather, Rear LEDs, Bluefin, Milltek, vwr intake, Focal speakers.
Offline Raffe
Re: What's the best mods to improve the handling?
« Reply #1 on: 27 May 2013, 08:35 »
The Bilstein B12 kit is Eibach springs matched to shortened Bilstein dampers, an uprated rear ARB and front if your feeling flush should tighten it all up, brakes there are loads of options pending your budget.
The MK5 boys & girls like to go for Porsche calipers on the standard disc size which keeps weight down and improves stopping power, or you go S3/.:R bigger calipers and discs which are relativelt cheap but they are also incredibly heavy...or start spending ££££ on aftermarket calipers with floating discs....
As said loads of choices :grin:
Offline mkviken
« Reply #2 on: 27 May 2013, 11:14 »
Buy a clio 200
Failin that B12 kit is way better than standard. Handles better, body control on the brakes And acceleration miles better and its even better on the bumps.
I can honestly say mine rides better than standard after fittin the B12
WALK and rear sway bar were worth fitting.
Bump steer kit a waste of money IMO
Better tyres would generally make it handle and stop better.
I might be selling my B12 kit if I can be arsed to take it off as I have my car to the mrs and she's not bothered about bling parts.
Golf GTI 7.5 230 white silver
Offline Neil gti
« Reply #3 on: 27 May 2013, 11:18 »
Cooper S through the pot holed twistys will take some beating in a heavy GTi
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline mkviken
« Reply #4 on: 27 May 2013, 11:33 »
On a rough b road my GTI will beat my clio as its much better over the imperfections and has more wheel travel.
Or maybe its just you have to be more commited in the clio whereas the golf is easier to drive in those conditions. It drives itself to be honest and isn't the most involving car to drive.
I know mini's are closer to the clio ethos than the golf but on rough b-roads every mini I've had just tie themself in knots. Run flat tyres and no wheel travel don't work unless the road is smooth.
If the road is smooth though the clio will murder the golf. I'm having to reclaibrate my brain to what I can do in the clio compared to the golf and stop bracing myself ready for body roll etc.
Horses for courses.
Offline Raffe
« Reply #5 on: 27 May 2013, 12:21 »
Just watch the LOOS in the Clio :evil:
Offline mkviken
« Reply #6 on: 27 May 2013, 12:29 »
I mustn't be down with the kids. Don't know what LOOS stands for
Offline Raffe
« Reply #7 on: 27 May 2013, 13:21 »
Sorry, Lift Off Oversteer.
Offline mkviken
« Reply #8 on: 27 May 2013, 15:35 »
Not on the 200
The 182 I had was very lively with 'LOOS' the 197 and 200 in particular are very neutral.
The 172/182 were known for it and like the 205,106/VTS caught alot of people out.
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #9 on: 27 May 2013, 15:39 »
This Mod bought a cayman, I'm very happy with my OEM Bilstein suspension :wink:
No loos here btw
