Author Topic: 16v Water flange removal _ Help Needed...  (Read 1250 times)
Offline Spam
« on: 26 May 2013, 20:49 »
The water flange to the front of the engine has sprung a leak. i have a replacement but i'm having trouble removing the allen key bolts.
Can anyone tell me what size the allen key needs to be to remove? Or is there a tool i can get to get the x3 bolts undone?
Any advise would be appreciated.
Thx
VW BUSH
Re: 16v Water flange removal _ Help Needed...
« Reply #1 on: 26 May 2013, 20:51 »
5 or 6 mm iirc
« Reply #2 on: 26 May 2013, 21:46 »
Try and get an allen key socket so you can then use a ratchet on it, should do the trick.
Offline itavaltalainen
« Reply #3 on: 27 May 2013, 17:30 »
think they are M6x20 or M6x22 bolts
