Is it feasible to reuse the OEM brake pad wear indicators with aftermarket pads?I'm looking at a set of Mintex 1144, however these don't come with wear indicators so wondering it the ones I have on at the moment can be moved over.Thanks
Quote from: vala on 26 May 2013, 17:22Is it feasible to reuse the OEM brake pad wear indicators with aftermarket pads?I'm looking at a set of Mintex 1144, however these don't come with wear indicators so wondering it the ones I have on at the moment can be moved over.ThanksJust leave your old one plugged in so you don't get a warning light and then replace your pads when needed. You don't need a little sensor to tell you when your pads are low
Quote from: scarr89 on 26 May 2013, 18:08Quote from: vala on 26 May 2013, 17:22Is it feasible to reuse the OEM brake pad wear indicators with aftermarket pads?I'm looking at a set of Mintex 1144, however these don't come with wear indicators so wondering it the ones I have on at the moment can be moved over.ThanksJust leave your old one plugged in so you don't get a warning light and then replace your pads when needed. You don't need a little sensor to tell you when your pads are low The old sensor is attached to the pads though If you remove the sensor from the pads you will break the wires and the indicator light will be on anyway...
dont you just unplug them and it will never show a warning light. My golf 1999 does not have one plus the 6 cars before that ,do newer cars after 2000 only have these sensors. Just unplug them should be fine.
A resistor will be needed to prevent the light from coming on.
