Author Topic: Odd coolant temp readings  (Read 3079 times)
Offline Dom Mk3
  • Insert wit here
« on: 08 August 2005, 13:10 »
My driver sits on 90 degrees when stationary but on a run will sit at, below or just above 70 degrees. Is this right?
Offline Bazzer
Re: Odd coolant temp readings
« Reply #1 on: 08 August 2005, 14:04 »
Don't see why not. When you're still there's no airflow to the engine. When you're moving, it's got plenty of air to blow through!.
Bazzer
mrwotto
« Reply #2 on: 08 August 2005, 18:27 »
My 16v sticks at 90c in traffic or when running, fan cuts in very quick to keep the temp down
Offline DUNNY
« Reply #3 on: 08 August 2005, 19:25 »
my 8v runs at 70 but when stopped rises to 90 quite quickly but once you get going again its back to 70
mrwotto
« Reply #4 on: 08 August 2005, 19:31 »
I have never seen mine rise above 90 to be honest
Offline Dom Mk3
  • Insert wit here
« Reply #5 on: 08 August 2005, 19:32 »
I understand why this happens, just wondering if it should. Thermostat stuck open perhaps?
Offline Overseer
« Reply #6 on: 08 August 2005, 20:26 »
Yup.. upon startup it takes about a mile/few minutes for the needle to move at all, then it moves to 70 or 90 depending upon whether its had much load.
Yup mines does too...
I have.. but I had a coolant leak at the time  :embarassed: the car self protects once its spurting coolant out and pressure drops.. heh
« Last Edit: 08 August 2005, 20:27 by Overseer »
Offline mysticblue_mk3
« Reply #7 on: 08 August 2005, 23:58 »
Funny you should mention coolant temp readings, I noticed the other day that mine reads 70 all the time, both stopped and on the move :huh:, never had a problem with it over-heating though.
Offline adyh
« Reply #8 on: 09 August 2005, 10:12 »
My coolant , after initial warm up period , sticks at ninety .
Engine oil quivers between 90 and 102 , dependant on the heavyness of my right foot  :evil:
Offline Jamie
« Reply #9 on: 09 August 2005, 10:23 »
My Driver seems to be losing coolent and I don't know where from.  Have to top it up every 2 weeks!!  It did it a while ago but stopped when I changed to expansion tank cap but the problem is back again and this time it isn't coming from the cap.  There is no nasty stuff in the oil so I don't think its the head gasket.  There are no visable sign at all.  Any ideas out there?
Jamie
