Author Topic: mk3 gti 8v  (Read 1874 times)
Offline mervsnart
mk3 gti 8v
« on: 25 May 2013, 15:44 »
hi peeps, just bought a 97' 8v gti, starts and is a sweet runner but wont rev past 4000 revs and then spits back thru the exhaust......would this be the hall sensor? thanks in anticipation. :wink:
Offline GOLF-MK3-GTI
Re: mk3 gti 8v
« Reply #1 on: 25 May 2013, 15:47 »
Could be or it could be your timings out
Gavv8
Re: mk3 gti 8v
« Reply #2 on: 25 May 2013, 16:24 »
I'm sure this has been covered before as being something to do with the distributor.
VW BUSH
Re: mk3 gti 8v
« Reply #3 on: 25 May 2013, 16:50 »
yep.
Scan it for codes, it should come up with hall sensor fault code out if its timing or faulty hall sensor.
Set to TDC, and check line up of rotor to timing mark on the dizzy body as it should be bang on.
Dizzy can be turned  a small amount to correct if the inter shaft is a couple of teeth out, some dizzys have dowels to stop them moving just pull one out in that case.
Worth checking bottom pulley is lined up correctly but normally its the inter thats moved as it spins pretty freely and moves easy when fitting a new cam belt and can jump a tooth without noticing.
If timing is spot on then its 99% the hall sensor, another scan should confirm
Search U281 code reader for budget code reader, a must have for Mk3 ownership :smiley:
Offline mervsnart
Re: mk3 gti 8v
« Reply #4 on: 25 May 2013, 17:04 »
all very useful chaps thanks, would my dlc be a 16 pin or a 2+2 conection?
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: mk3 gti 8v
« Reply #5 on: 25 May 2013, 17:09 »
Will be 16 pin being a 97 model mate.
Re: mk3 gti 8v
« Reply #6 on: 25 May 2013, 20:35 »
Could also be your cam timing out
