Author Topic: Need help diagnosing clutch or gearbox problem!  (Read 2628 times)
Offline b_boy02
Hello!
I have noticed recently that my 16v is resisting me changing gear, it kinda feels like I can't push the gear stick into the gate without a bit of force and sometimes it is hard to find the gate at all! I have also noticed today that it is crunching a tiny bit into third sometimes. It has crunched into reverse since I have had it.
I am unsure if this is a gearbox, clutch cable, or clutch itself problem...
Does anyone have any ideas??
Thanks for your help.
VW BUSH
Re: Need help diagnosing clutch or gearbox problem!
« Reply #1 on: 24 May 2013, 15:08 »
Hello!
How many miles has it covered?
Offline b_boy02
« Reply #2 on: 24 May 2013, 15:24 »
140k
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 24 May 2013, 18:08 »
16v doent have a cable,sounds like the clutch isn't clearing ,does it go into the gears easy when the engine isn't running,my 16v box is nearly at 180k and still sweet even being coupled to a 20v .
Gavv8
« Reply #4 on: 24 May 2013, 18:15 »
Could be the nylon ball at the base of the shift tower, you can get a kit to repair it.
Offline b_boy02
« Reply #5 on: 25 May 2013, 11:05 »
Yes Screech it does change gear easy when the engine is not running...what would that point to?
Gav, I had a look at the shift tower yesterday and all seems fine visually and if you change by hand in the engine bay. Don't know how I would tell if it is this nylon ball thing though!?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 25 May 2013, 13:07 »
16v, VR6 & TDI gearsticks don't have a nylon pivot ball base like the 8v rod change set up.
VW BUSH
« Reply #7 on: 25 May 2013, 14:29 »
Indeed, Cable selection and hydro clutch.
Could be cable issue, could be slave, you need to rule these out before you start thinking about the box itself
Offline tweed
« Reply #8 on: 25 May 2013, 14:39 »
If it was clutch it would slip.
My thoughts are problem between gear stick and clutch
« Reply #9 on: 25 May 2013, 14:55 »
Worn out plastic selector levers on the shift tower?
